6. Toyota Prius hybride rechargeable (2023) - La fiche technique
| MOTEUR THERMIQUE | PRIUS HYBRIDE RECHARGEABLE |
| TYPE | 4 CYLINDRES EN LIGNE, 2.0 L HYBRID DYNAMIC FORCE |
| DISTRIBUTION | 16 SOUPAPES DACT |
| ALIMENTATION | INJECTION D’ESSENCE |
| CYLINDREE (CM3) | 1 987 |
| ALESAGE X COURSE (MM) | 80,5 X 97,6 |
| TAUX DE COMPRESSION (:1) | 14,0 |
| PUISSANCE MAXI (CH / KW @ TR/MN) | 152 / 112 @ 6 000 |
| COUPLE MOTEUR THERMIQUE SEUL (NM @ TR/MN) | 190 @ 4 400-5 200 |
| SYSTEME HYRBIDE RECHARGEABLE |
| BATTERIE HYBRIDE | LITHIUM-ION |
| CAPCITE DE LA BATTERIE (kWh) | 13.6 |
| TYPE DU MOTEUR AVANT | MOTEUR SYNCHRONE A AIMANT PERMANENT |
| PUISSANCE MAXI MOTEUR ELECTRIQUE (CH / KW ) | 163 / 120 |
| COUPLE MAXI MOTEUR ELECTRIQUE (NM) | 208 |
| PUISSANCE CUMULEE (CH / KW) | 223 / 164 |
| PERFORMANCES |
| VITESSE MAXI (KM/H) | 177 |
| ACC. 0-100 KM/H (SEC) | 6,8 |
| CONSOMMATION D’ENERGIE | 17” | 19” |
| CYCLE MIXTE WLTP (L/100 KM) | 0.5 | 0.7 |
| CYCLE MIXTE WLTP (Wh/KM) | 114 | 125 |
| CO2 / KM WLTP (G) | 11 | 16 |
| HOMOLOGATION | EURO 6 AP | |
| AUTONOMIE 100 % ELECTRIQUE (KM) | 86 | 72 |
| CAPACITE DU RESERVOIR (L) | 40 | |
| CHASSIS | 17” | 19” |
| SUSPENSION AVANT | MACPHERSON | |
| SUSPENSION ARRIERE | DOUBLE TRIANGLE | |
| DIRECTION | CREMAILLERE & PIGNON | |
| NOMBRE DE TOURS DE VOLANT, BUTEE A BUTEE | 2,84 | 2,76 |
| DIAMETRE DE BRAQUAGE ENTRE TROTTOIRS / ENTRE MURS (M) | 5,3 / 5,6 | 5,4 / 5,75 |
| DIMENSIONS EXTERIEURES (MM) | 17” | 19” |
| LONGUEUR | 4 599 | |
| LARGEUR | 1 782 | |
| HAUTEUR | 1 420 | 1 430 |
| VOIE AVANT | 1 563 | |
| VOIE ARRIERE | 1 579 | 1 580 |
| EMPATTEMENT | 2 750 | |
| PORTE-A-FAUX AVANT | 974 | |
| PORTE-A-FAUX ARRIERE | 875 | |
| GARDE AU SOL | 137 | 144 |
Photos (43)
